secured way of using credentials in BP
KirankumarMahan
Hi All, Could any one know what are the different ways available in the blueprism to use application user ID and passwords in secure way. please suggest me. Regards, Kiran
As well as storing credentials in the Blue Prism Credential Manager, I suggest building password change processes for each application. The Password Change processes will simply follow the process within the application to change the password - and the new password will be generate by the Blue Prism process and saved to back to credential store. If Blue Prism not only stores the credentials using 256bit encryption - but also has changed the credentials itself - than no human user will know the credentials and, if access to the Production environment is limited as it should be, it is impossible for anyone outside of a running blue prism session to use that credential.
