surface automation PDF
PankajWalia1
I am trying to read the coordinates on the selected text as a result of "search" on PDF.  Plan is to use those coordinates to  "Read Image" for the region using dynamic values for start x, start y etc.  Is there a way to get those coordinates of the region?
Pankaj Walia
Architect
Wipro
America/New_York
GopalBhaire
Level 10
That'll be tough, why don't you copy all the text of pdf (ctrl a + ctrl c) into a dataitem and use string operation on it to get desired text.
Gopal Bhaire
Analyst
Accenture
thanks for your reply..
I want to check if the selected text is "red" colored so we can create a link to it. If it is not of that color I would want to skip any processing.
So basically I was thinking of creating a "dynamic" region that can be created once I have the coordinates of the selected text. Is there a way to get those coordinates?
Once I know the coordinates on the screen I can then try to read the text on that region.. Hope it makes sense.  Any other suggestions you may have let me know..
Pankaj Walia
Architect
Wipro
America/New_York
