- Mark as Read
- Printer Friendly Page
21-03-24
01:49 PM
Status:
New
- Filter functionality is currently set to only one filter per data field/column. We would need functionality to apply AND/OR filtering at numerous levels within a particular data field. For example, if the user works on portfolio's CS_CABSLF and CS_ALPEN then we would like the ability to filter the 'Item Key' data field to be CS_CABSLF OR CS_ALPEN. There should be no limit to the number of levels we can filter a particular field for. Again, if a particular user works on 12 different funds, we would have 12 levels of OR filtering within said column/data field.
- There is no functionality to move columns around within the view in a different order. We are referring to drag and drop functionality on screen.
- Column width appears to be pre-defined and user does not have ability to expand or shrink a particular column based on underlying data length.
- If the underlying value in the column goes out further then the current column width, the UI merely adds '…' and we cannot see the entire value. For example, item key 'CS_CABSLF - 1/8/2024 - Rerun 15014…' or Exception Reason 'Max Retry Reached - GoCheck Ticket 10...' or Tags 'Exception: Max Retry Reached - ...' - there is no ability for the user to see the entire wording on screen within the UI. Ideal solution would be to introduce the wrap text functionality per column.
- User should have capability to retrigger a process within the Work Queue screen. For example, item key 'CS_CABSLF - 12/21/2023 - Rerun 193554
