ChristopherJank
Level 7
Status: Delivered
I want have a calendar option to load the public Hollidays per Default for Germany
2 Comments
Hi Christopher,
Are you looking for the addition of German calendars specifically or the ability to import your own custom calendars that would then exist independently of the preset calendars that are provided with Blue Prism?
Rob
MelanieGiuliani
Community Team (Retired)
Hi Christopher,
Thank you for submitting your idea! This feature was included in v6.8, which was released in June. As such, I have marked your idea as Delivered.
Thank you,
Melanie
