HanumanthYemmet
- Mark as Read
- Printer Friendly Page
19-02-20
08:35 AM
Status:
Not Planned
When working the code stages, if a code is not used or kept aside to have look later then Blueprism will not allow to run the process or object.
throws error to fix that, even we are not using that.
unused code stages might be many but then also we should be able proceed with step in or run the process/object.
1 Comment
