EVIPUTI
Can we create a mobile app where we can see all our process , robots , status and can Monitor the process from mobile phone can be really cool.Administrators can now supervise their entire RPA environment from anywhere, at any time, using an iOS- or Android-based device.
Complete visibility into your RPA environment, even when you’re not at your desk or in the office .Control room to trigger real-time alerts on the performance of your Robots or provide critical scheduling and licensing information. You can also view detailed at-a-glance dashboards to quickly understand exactly what’s happening in your RPA environment as it happens.!!
7 Comments
Referencing https://portal.blueprism.com/product/product-portfolio-roadmap , you can find "Control Digital Workforce (Beta) – A new browser-based user interface (UI) for controlling your Digital Workforce" in the product roadmap
Browser based is okay but it would be more efficient and better if they launch app for Android and iOS platforms. That's kind of much needed piece missing right now is BluePrism.
MelanieGiuliani
Community Team (Retired)
Hi Vipul,
Thank you!
Melanie
KeerthanaJegann
If we would like to monitor processes on weekends, process which are time sensitive and if laptop is not accessible, monitoring process in control room via mobile device would be really helpful.
Mukeshh_k
Hello All, as we might have faced challenges in having 100% availabilities of RPA Support/Controllers on numerous occasions either when we are out of office, after office hours or are on short staffs some days - it would be a nice idea to have an iOS/Android based mobile app for minimal activities such as force retry, restarting a bot, running any particular ad-hoc processes at times, Also to ensure our businesses are supported at their time, when we are working globally on different timezone and are keen on achieving the idea of effective automation and optimised license utilisation.
It should make controllers/Support Team lives easy. Kindly Thumbs up and support the idea If you agree to this Idea of having Mobile based app for control room or you have been in similar situation at your workplace and during BAU at odd hours.
Mukesh K
EmersonF
Hey @Mukesh Kumar ,
I believe that this can make easily with Power Apps, Mybe a Collab between SSC and MS.
Mukeshh_k
Emerson Ferreira - Have you guys implemented it ? it would be good idea to look through something similar if its already been thought and built using MS. Let me know if you would like to connect!
