Having an Inbox for each of the Forms that a user has access to.
Right now it's all piled into one Inbox requiring a filter for the Form Name.
For each Inbox by Form, have the ability to add filters based on the fields available in the form. e.g. if a form has a Date Field, I should be able to add the Date Field as a filter and sort.
