Blue Prism® Guide to OLEDB
16-06-22 09:09 AM
I am working on the above course, i am working through the options for using SQL as it is something that will be integral to a project myself and my colleague will be working on later this year. However i cannot get the INSERT INTO part working, i have copied the example one and adjusted the sheet names to match and data columns to match but it keeps coming up with a Syntax error, i have tried using every way i can think to alter the SQL string to work but each time it does not seem to happen. I dont have much experience using SQL language so iam worried i'm a bit stuck since i have been trying since yesterday. Could anyone offer some advice on how to get this to work?
17-06-22 06:48 PM
Hi John
Can you share an example of the sql you are trying to run? also have you checked you are setting the connection to the database correctly?
