Digital Exchange
 View Only
last person joined: 5 days ago
This community is a place to discuss Blue Prism DX assets and development.
  • 1.  Multiple Power Slides can be copy and Past in One Power Point Presentation document
    Posted 08-21-2023 15:57
    I have multiple Power Points slides in different different folder and my requirement is how to copy Power Point slide from different folder and Past it in One power Point presentation.
    Can you please help me how to achieve.
    Thanks & Regards,
    Pralay
    Pralay Das
  • 2.  RE: Multiple Power Slides can be copy and Past in One Power Point Presentation document
    Posted 08-24-2023 21:44
    You can use to copy the files from one folder to another the "Function for Utility - File Management - 10.3.1" (LINK HERE
    This one can copy and move slides in PowerPoint "Function for Vuram MS PowerPoint VBO" (LINK HERE)
    Luis Lopez
    Blue Prism Ltd
  • 3.  RE: Multiple Power Slides can be copy and Past in One Power Point Presentation document
    Posted 30 days ago
    Hi Luis,
    Thank you for your suggestion. But is there any way one Power Point doc. having multiple slides in that case how can I copy multiple slides from same document and keep in separate folder so that from that folder one by one can copy and past in Final Power Point document. Cany you please help on this. Given below is the sample Power Point document from here need to copy multiple slides. Example
    Pralay
    Pralay Das
  • 4.  RE: Multiple Power Slides can be copy and Past in One Power Point Presentation document
    Posted 27 days ago
    I have created a sample that summarizes all the PowerPoint slides in a given folder.
    Is this what you mean?
    Yoshiyuki Wada
  • 5.  RE: Multiple Power Slides can be copy and Past in One Power Point Presentation document
    Posted 27 days ago
    Thank you Yoshiyuki Wada for your suggestion. Same kind of flow I have already created and it is working.
    Pralay
    Pralay Das
Blue Prism Digital ExchangeDX Asset IdeasContact DX Support
FAQs
The Blue Prism Digital Exchange (DX) is an online marketplace where businesses can instantly access, apply and share pre-built AI, cognitive and advanced RPA technologies from best-in-class providers. These assets easily connect to existing digital workers, systems and processes to enhance automation capabilities.
The Digital Exchange is free to all users. Most of the content on the DX is free to download but there are some submissions that do have a cost associated. The submissions with a cost are advertised on the asset card and profile. No unwanted costs will be applied to any users.
You can visit and browse the Digital Exchange here. If you would like to consume or download any material it is necessary to create an account on the Blue Prism Portal first.
Everyone can access the Digital Exchange and consume the assets on it. If you would like to contribute to the marketplace it is necessary that you create an account and sign up as a partner.
