Blue Prism Product
 View Only
last person joined: 9 hours ago
This community covers the core Blue Prism RPA product.
  • 1.  Read From Dropdown
    Posted 10-10-2022 13:34
    Our requirement is to read a VALUE from a web page. The VALUE keep on changing as per user raised the request( Which is basically a Dropdown (Ex: A or B or C or D) button while raising a request). After the request been raised, the value will be static(Let say: D).
    So the problem we are facing is each time we spied it using Browser Mode & used "GET CURRENT VALUE" or "GET TEXT", we are getting result as the whole values under the DROPDOWN, instead of ONLY "D".
    As per the above example, Result: ABCD
    Required Result: D
    Blue Prism : V 6.10.4
    Browser: V106.0
    Kindly advise.
    Simanchala Pattanayak
    Lead Solution Advisor
    Deloitte USI
    Bangalore
  • 2.  RE: Read From Dropdown
    Posted 10-10-2022 13:37
    Hi @Simanchala Pattanayak,
    Whenever you deal with a dropdown, always make sure to try spying both the inner field of dropdown and outer field of dropdown. In your case, it seems you might have spied the outer field of dropdown, which is giving you the result of all 4 values. Try spying the inner field and hopefully, it will give you the correct value​
    Manpreet Kaur
    Manager
    Deloitte
    *If you find this post helpful mark it as Best Answer
  • 3.  RE: Read From Dropdown
    Posted 10-10-2022 14:13
    Hello Manpreet,
    Thanks for replying.
    Actually we are getting a single option to identify (Not getting both Inner & Outer spying option)​
    Deloitte USI
    Bangalore
  • 4.  RE: Read From Dropdown
    Posted 10-10-2022 16:06
    Hello @Simanchala Pattanayak,
    Did you try using any other mode e.g. UIA or AA mode for achieving the same functionality?​
    Manpreet Kaur
    Manager
    Deloitte
  • 5.  RE: Read From Dropdown
    Posted 10-10-2022 16:23
    Hello Manpreet,
    Are they reliable for a Web Application. Because previously we observed some cases where for the UIA mode the Blue Prism application itself used to get hang & terminate. AA Mode is not available. We are getting only Browser, Win32, UIA & Region mode here.
    Deloitte USI
    Bangalore
  • 6.  RE: Read From Dropdown
    Posted 10-11-2022 13:54
    Hi Simanchala,
    try to read use Get Selected Item Texts it returns collection but in my case it returns the value which is selected or choose Get Selected Item which returns two columns collection.
    Zdenek
    Zdeněk Kabátek
    Head of Professional Services
    NEOOPS
    http://www.neoops.com/
    Europe/Prague
  • 7.  RE: Read From Dropdown
    Posted 10-12-2022 13:45
    You can try using the UIA Mode to spy the element and do Get Text/Get Value which will give you the selected value for that dropdown field. It worked for our web applications.
    Usha Chukka
    Senior executive
    Cyient
    Indian/Antananarivo
  • 8.  RE: Read From Dropdown
    Posted 10-12-2022 14:14
    In addition you can also refer to this.
    https://community.blueprism.com/communities/community-home/digestviewer/viewthread?GroupId=385&MessageKey=6dfcfd0f-c72b-4444-87a2-8360165ead43&CommunityKey=1e516cfe-4d1f-4de9-a9eb-58d15bf38c81
    Thanks!
    Anil Kumar Juttada
    RPA Business Analyst
  • 9.  RE: Read From Dropdown
    Posted 10-13-2022 13:24
    Hello All,
    We can able to read the element now using Browser mode, but the issue is in the output we are getting the Dropdown values, instead of the value present over the web page.
    Kindly suggest how to read.
    FYI: In the normal BROWSER MODE, usually while identifying a wen element, we used to get an OUTER & an INNER element to read. But here we are getting only the OUTER element.
    Deloitte USI
    Bangalore
Welcome to the Blue Prism RPA Product Community!
Whether you’re looking to manage a complex infrastructure, maintain security and compliance, bring new products to market faster, or gain operational speed and agility in an uncertain economy, Blue Prism delivers — with the flexibility you need to create the business you want. From deployment on-premise, through a cloud service provider or as SaaS, to a skillful and adaptable digital workforce that continually expands to meet your enterprise needs, you can gain enhanced operational insight and control while your people reclaim the time they need to focus on great work.
Product PageKnowledge BaseBlue Prism Training Offering
Product Research ProgramUpdates, Releases & Announcements
FAQs
Blue Prism is intelligent automation — business-developed, no-code automation that pushes the boundaries of robotic process automation (RPA) to deliver value across any business process in a connected enterprise.
A combination of RPA with expanded cognitive and AI capabilities, Blue Prism is different than other automation technology on the market. With one Blue Prism license, you gain instant access to an already AI equipped digital workforce, along with the tools you need to build and delegate automations. Click here for more information on Blue Prism and Intelligent Automation.
To learn more about how Blue Prism RPA can help your organization and how much it will cost to get started, please Contact our Sales department.
Blue Prism RPA can be downloaded from our customer portal. If you would like to consume or download any material it is necessary to create an account on the Portal. Once you have registered, you can access the download options for Blue Prism here.
Yes! Installed on your own machine and supported by our training materials and product documentation, you can use all the features of the full enterprise product for free with our Blue Prism Trial – giving you the opportunity to learn the basics before moving to a full production implementation. Click here for more information and to download the trial.
Yes! You can access our known issue list for Blue Prism from our Support Portal.
Regardless of your industry, Blue Prism’s Digital Workforce can adhere to strict governance and compliance standards without limiting productivity. Click here for more information on how your industry can benefit from Blue Prism.
