Blue Prism Product
 View Only
last person joined: 7 hours ago
This community covers the core Blue Prism RPA product.
  • 1.  Ultima IA-Connect vs Blueprism 7.0 CITRIX automation
    Posted 06-13-2022 08:15
    Hi All,
    At present we are using Ultima IA Connect tool for automating the CITRIX hosted applications.
    I came to know that #blueprism ver. 7 has CITRIX automation functionality similar to #Ultima IA Connect ​.
    What we have experienced till now with ULTIMA is:
    • Ultima is very fast there is no delay in searching the CITRIX element spied via Ultima.
    • We are able to automate all kind of applications like, JAVA, Web, Windows.
    • All excel, file management and other basic VBOs are provided in package.
    • Good customer support and many more.
    Is there any comparison or analysis done between both the tools.
    Will we be able to write custom codes which executes at other end, excel actions, file management in BP ver 7 and above.
    Rahul Vyas
    BNP Paribas
  • 2.  RE: Ultima IA-Connect vs Blueprism 7.0 CITRIX automation
    Posted 06-13-2022 11:52
    Hi @Rahul Vyas,
    I'm not aware of any specific comparison that's been put together. If you're already using Ultima-IA Connect, and it's working as well as you state, why would you be concerned with changing it? As the saying goes: "If it ain't broke, don't fix it."
  • 3.  RE: Ultima IA-Connect vs Blueprism 7.0 CITRIX automation
    Posted 06-13-2022 12:21
    Haha,
    Thanks for the response, Actually I was thinking if we can save Ultima license cost there for the upcoming projects. Anyways we are going to get upgraded to 7.X version by this year, We thought if we can take up new CITRIX projects accordingly.
    Rahul Vyas
    BNP Paribas
  • 4.  RE: Ultima IA-Connect vs Blueprism 7.0 CITRIX automation
    Posted 06-13-2022 13:06
    @Rahul Vyas,
    I'd say your best bet is to install a copy of the v7 Learning or Trial edition in you dev/test environment. Then create a copy of one of your processes, replace the necessary pieces handled by Ultima, and see how it goes.
  • 5.  RE: Ultima IA-Connect vs Blueprism 7.0 CITRIX automation
    Posted 08-03-2022 08:02
    Hi @Rahul Vyas
    I hope you are doing well,
    Wanted to check if you were able to find any comparison or analysis done between both the tools? As it makes sense on saving the license cost of ultima.
    Lakshay Chopra
    TEAM LEAD - RPA
    lakshay chopra
  • 6.  RE: Ultima IA-Connect vs Blueprism 7.0 CITRIX automation
    Posted 08-03-2022 13:32
    Hi Lakshay,
    I am still searching for some proper comparison between both. We have a meeting scheduled with blueprism in upcoming week.
    As far as I know the blue prism 7.X will have CITRIX desktop automation feature but not the XenApp automation(Still need confirmation). This is going to be deciding factor for now.
    Will let you know once I have something more.
    Rahul Vyas
    BNP Paribas
  • 7.  RE: Ultima IA-Connect vs Blueprism 7.0 CITRIX automation
    Posted 09-16-2022 09:52
    HI @Rahul VyasEric Wilson ,
    Would you by any chance have any update on the above?
    Also needed some guidance on the below questions
    1. Do we need multiple licenses for Runtime resource and CITRIX VDE in BLUEPRISM 7.0?
    2. Do we need multiple licenses for Runtime resource and CITRIX VDE in BLUEPRISM 7.1.1?
    3. Do we Need to install full package in 7.0 for Runtime resource and inside the Citrix VDE ?
    4. Do we Need to install full package on runtime resource and only Citrix agent in 7.1.1 inside the Citrix VDE ?
    5. Do we need a different license for CITRIX Agent ?
    6. How do we move blue prism installer.EXE within the CITRIX VDE?
    Any information as to why CITRIX AUTOMATION is disabled for trial versions of blueprism ?
    Lakshay Chopra
    lakshay chopra
Welcome to the Blue Prism RPA Product Community!
Whether you’re looking to manage a complex infrastructure, maintain security and compliance, bring new products to market faster, or gain operational speed and agility in an uncertain economy, Blue Prism delivers — with the flexibility you need to create the business you want. From deployment on-premise, through a cloud service provider or as SaaS, to a skillful and adaptable digital workforce that continually expands to meet your enterprise needs, you can gain enhanced operational insight and control while your people reclaim the time they need to focus on great work.
Product PageKnowledge BaseBlue Prism Training Offering
Product Research ProgramUpdates, Releases & Announcements
FAQs
Blue Prism is intelligent automation — business-developed, no-code automation that pushes the boundaries of robotic process automation (RPA) to deliver value across any business process in a connected enterprise.
A combination of RPA with expanded cognitive and AI capabilities, Blue Prism is different than other automation technology on the market. With one Blue Prism license, you gain instant access to an already AI equipped digital workforce, along with the tools you need to build and delegate automations. Click here for more information on Blue Prism and Intelligent Automation.
To learn more about how Blue Prism RPA can help your organization and how much it will cost to get started, please Contact our Sales department.
Blue Prism RPA can be downloaded from our customer portal. If you would like to consume or download any material it is necessary to create an account on the Portal. Once you have registered, you can access the download options for Blue Prism here.
Yes! Installed on your own machine and supported by our training materials and product documentation, you can use all the features of the full enterprise product for free with our Blue Prism Trial – giving you the opportunity to learn the basics before moving to a full production implementation. Click here for more information and to download the trial.
Yes! You can access our known issue list for Blue Prism from our Support Portal.
Regardless of your industry, Blue Prism’s Digital Workforce can adhere to strict governance and compliance standards without limiting productivity. Click here for more information on how your industry can benefit from Blue Prism.
