Hello Miya,
You can create a Number data item called Priority. Keep this number incrementing in your loop.
In your Load Queue action pass this Data item in the Priority input parameter.
This will keep incrementing your priority for each row and you will see items getting added to the queue with increasing priority order.
Thanks & Regards,
Tejaskumar Darji
Sr. Consultant-Technical Lead
