How to Integrate Power BI Dashboard and Blueprism Queue?
AlanTuring
I need to make a power bi dashboard with the blueprism queue information
Soumya21
Hi @AlanTuring
I think you need to connect with SQL server which is used to connect blue prism where you will be having all queue data.
You can integrate SQL server with Power Bi then all you can create dashboard.
If you have not already seen, The Splunk Dashboard asset on DX https://digitalexchange.blueprism.com/dx/entry/3439/solution/blue-prism-analytics-for-splunk can be referred here as an example on how the BP queue info is retrieved and transformed into dashboard.
check this article: https://community.blueprism.com/communities/community-home/digestviewer/viewthread?GroupId=145&MessageKey=6354e3bb-b0a1-472a-ae21-3ca1d3b89e4a&CommunityKey=3743dbaa-6766-4a4d-b7ed-9a98b6b1dd01
