Multiple Power Slides can be copy and Past in One Power Point Presentation document
21-08-23 03:57 PM
I have multiple Power Points slides in different different folder and my requirement is how to copy Power Point slide from different folder and Past it in One power Point presentation.
Can you please help me how to achieve.
Thanks & Regards,
Pralay
Pralay Das
24-08-23 09:44 PM
You can use to copy the files from one folder to another the "Function for Utility - File Management - 10.3.1" (LINK HERE)
This one can copy and move slides in PowerPoint "Function for Vuram MS PowerPoint VBO" (LINK HERE)
Luis Lopez
Blue Prism Ltd
25-08-23 04:00 PM
Hi Luis,
Thank you for your suggestion. But is there any way one Power Point doc. having multiple slides in that case how can I copy multiple slides from same document and keep in separate folder so that from that folder one by one can copy and past in Final Power Point document. Cany you please help on this. Given below is the sample Power Point document from here need to copy multiple slides. Example
Pralay
Pralay Das
28-08-23 03:20 AM
I have created a sample that summarizes all the PowerPoint slides in a given folder.
Is this what you mean?
Yoshiyuki Wada
28-08-23 07:06 AM
Thank you Yoshiyuki Wada for your suggestion. Same kind of flow I have already created and it is working.
Pralay
Pralay Das
