Starting a process using AutomateC.exe from external systems
Kishore_KumarDe
Is it possible to start/stop a Blueprism process from an external system using AutomateC.exe? If yes, then how can we achieve it and if there is any security concerns in doing that?
Kishore Kumar Deka
Senior System Engineer
EPAM
America/New_York
If my answer provided any assistance, please vote as "Best Answer". Kishore Deka Lead Software Engineer EPAM systems Connect on LinkedIn https://www.linkedin.com/in/kishoredeka1410/
Hi Kishore - yes it's possible. The output from starting a process is the Session ID and with this you can check the status of the process and request a hard or soft stop. The command line interface requires authentication. If you check out the in-product Help there is a lot of info in there.
John Carter
Professional Services
John Carter
