Michael_S
Community Team (Retired)
If you're starting to plan an upgrade to your SS&C Blue Prism Enterprise setup, this is a good place to start! We've listed only the most useful resources here.
🤖 This isn't a definitive list, so if you can't find what you're looking for, be sure to ask in our Upgrades Support forum and we'll either point you to the right resource - or make a new one for you!
Key Resources for Upgrade Planning:
  • Should we upgrade? Decision tree: LINK
    A series of questions to ask to determine whether you need to upgrade now, next or later.
  • Plan your upgrade - Scale and strategy: LINK
    A documentation page covering key questions to ask before you upgrade, and the different approaches to executing an upgrade.
  • High-level upgrade stratagies: LINK
    Shows the various approaches to executing an upgrade along with their pros & cons.
  • Choosing the right target version: LINK
    Our community guide on how to select the SS&C Blue Prism Enterprise version that best suits your organization's needs.
  • Overview of SS&C Blue Prism Enterprise releases: LINK
    Get a rapid overview of what's new in every Blue Prism Enterprise release so far, with links to their full release notes.
  • Upgrade path limitations: LINK
    A table showing every version of SS&C Blue Prism Enterprise, and any limitations that apply in upgrading from one version to another.
  • Upgrade notices: LINK
    A tool that allows you to select your current version and your target version to get information about any specific tasks you'll need to carry out whilst upgrading.
  • Sample RACI charts: LINK
    A community template showing how you might organize the work to be done and accountabilities across the various stakeholders involved in your upgrade project.
  • Product Upgrade Assurance: LINK
    Partner with experts at SS&C Blue Prism on your upgrade project
  • Upgrade contingency planning: LINK
    A guide from our Robotic Operating Model 2 on how to make sure you have a Business Continuity Plan in place to support stakeholders should you experience unexpected issues.
  • Customer upgrade stories: LINK
    Three stories showing different approaches to carrying out upgrades across different timelines and risk appetites.
Version history
Last update:
‎20-02-26 03:56 PM
Updated by:
Contributors
