AA Spying Mode
SimphiweTshezi
How can I prevent AA Spy mode from highlighting underlying invisible fields?
Simphiwe Tshezi
Software Developer (RPA)
Altron Managed Solutions
Johannesburg
Simphiwe Tshezi Software Developer (RPA) Altron Managed Solutions Johannesburg
HarpreetKaur
Level 7
Have you tried any other Spy mode? UI-mode perhaps? Also you could try a combination of spy modes and Send keystrokes for some tricky controls,
Harpreet
Harpreet Kaur Product Consultant
JanČech
if your fields has fixed position in app GUI. You can try using Match index param. Sometimes could help also combination with param Order.
Best,
Jan
Jan Čech
Senior RPA Specialist
VWFS
EVIPUTI
Can you try ticking the Invisible attribute and setting its value to False ?
Vipul Tiwari
Senior Process Simplification and Optimization Designer(Solutions Architect)
Fidelity International
