Analysis for MS Excel
12-10-18 01:11 AM
Hi, just want to know if Blue Prism is capable of building an Object for Analysis for MS Excel (considering it is already installed in a remote desktop or Virtual Machine)? Thanks in advance!
15-10-18 04:37 PM
Can you expand your question a little, I'm not sure I understand.
15-10-18 10:10 PM
Thanks for replying John Carter. I am trying to create a business object for ""Analysis for Microsoft Excel"" which is an excel add-in used to fetch data from SAP via queries. I tried creating the business object by having its executable file run upon launch. However, it seems that this excel add-in can't be spied.
Do you have any idea if business object in BP can be created for ""Analysis for Microsoft Excel""? Thanks in advance!
16-10-18 12:27 AM
I'm not familiar with that add in but by default BP does not integrate with Excel via the UI, it's done via the Excel API (which is similar to macros). The Excel UI can be spied a little, but the best option is to integrate programatically. But whether this add in can be controlled via the API, I don't know. Maybe try experimenting by recording a macro, that might show you if API control is a possibility.
