Appman64 error when spying Oracle SQL Developer
dmurray21
Hi, I am pretty new to Blue Prism and I am trying to resolve an error we are getting when we try and spy on Oracle SQL Developer. As this is a Java program we have Enabled the Java Access Bridge, however when we try to spy java elements in Oracle SQL Developer the AppMan64 exe which Blue Prism uses crashes instantaneously. The problem module is identified as the WindowsAccessBridge-64.dll. Once we have gotten back into Blue Prism we get the error: €œExternal AppMan reader thread exited before response from query€ Software stack is Windows 2012 R2 Blue Prism v6.4.0 64 bit Oracle SQL Developer v4.1.3 64 bit JRE 1.7.0_45 (both 32 and 36 bit version) This version comes with the JAB bundled with it, so have just enabled this version. Think it is JAB v2.0.7 with this version of JRE.   Anyone else spying on Oracle SQL Developer at all and got this working? I have tried later versions of the JRE and Oracle SQL developer but get the same error as using the versions above.
Ravindersaini
Level 7
Hi, What is the Application manager mode for the application modeller ? If it is anything other than Embedded and than it would requires APPMAN. You can get more info on the below link. http://portal.blueprism.com/customer-support/support-center#/path/11585…  Regards, Ravinder Saini
