Attaching to Micro Focus Reflection
03-10-19 02:24 AM
Hi All,
I am working on an RPA process which involves interacting with mainframe using Micro Focus Reflect. I am looking to create an object for each screen I am interacting with in the system, which would require an attach action in each of the objects.
When setting up the object, I note that attaching to Reflect using a session identifier is not an option, and I am unable to attach to the session as I would with other systems (attach is not available in the navigate stage). Does anyone know if there is any other way to attached to Micro Focus Reflect, or do I simply have to configure all screens in the same object, which is against BP best practice?
Sam
Samuel Lai
Consultant
EY
Australia/Sydney
Sam
Samuel Lai
Consultant
EY
Australia/Sydney
26-08-20 04:14 PM
I am facing the same issue. Did you found the solution or workaround for this ? Please let me know
Ron
Ron
