Auto unlocking of processes
Hi, We are facing an issue where processes are being unlocked automatically. As a result we are loosing some work or we have to save the process with a different name. Process are being unlocked due to some other user as this facility is available in the new updated blue prism. Suggest some remedy for the same to avoid the same issue.
Surely this is a problem with your procedures, not the system. All users should adhere to an operating model/code of practice whereby they don't throw people off just like that, and at least check that the other user is not legitimately using the diagram.
