Automation.exe has stopped Error
BalakrishnaG
Hi, While interacting with web Application, Using Html Mode Click event is not working..it is highlighting the element but not clicking on that element..so we tried using AA mode. When ever we use AA Mode we getting "Automation.exe has stopped Error" and then automatically blue prism is closing. Why click event is not working in Web Application using HTML mode.   Thanks in Advance.
DamianBoczoń
Hi, Which BP version and what browser are you using? Are you sure that you spied this element correctly? It may be possible that you spied the container of your target element, not the element itself, hence the highlighting. Best Regards,
BalakrishnaG
We are using BP version 5...and we are using IE browser.. we have spied the element correctly. When we are using AA  mode we are getting automate.exe error and bp tool is getting closed automatically.   Thanks, Bala
DamianBoczoń
Is your website a SharePoint by any chance? If so, then take a look at this article https://help.blueprism.com/Automation-Design/Application-Integration/Active-Accessibility-Spy-Mode/1280268672/Why-does-Active-Accessibility-crash-Blue-Prism-when-spying-SharePoint.htm If not, are you able to share a link to the website? Best Regards,
BalakrishnaG
Hi We are using Ariba Web Application. i think we cant share the link of application.as it is client related information. thanks, Bala.
