BP 7.2 While Launching edge, unable to detect browser extension
25-07-23 02:34 PM
We are performing below steps
- Kill Edge(Utility-Env -> Kill Process)
- Launch edge with CommandLineParam(URL)
- Browser launches and 2 extensions are disabled and getting error 'The browser extension could not be detected.'
Is this a known issue in 7.2 ?
Sheela Parthasarathy
Assistant Vice President
Deutsche Bank Group
Pacific/Apia
25-07-23 03:28 PM
Screenshots are always helpful.
But based on the little information you have provided, it appears to me that you may need to reinstall/repair the Blue Prism browser extension and then retry.
Yinka Daramola
26-07-23 02:54 AM
Agree. There should only be one extension installed, reflecting your current BP version.
Also, in Edge settings turn off "Startup Boost", as recommended to us by BP support.
If that doesn't work, you might have to adjust the timeout settings in the automate.exe.config file in your Blue Prism installation directory. If you are uncomfortable doing so, open a support ticket and they will guide you through that process.
The default timeouts for launch and communication are, I believe, 2000ms and 3000ms respectively.
Brian Clayton
Applications Consultant
The Auto Club Group
America/Dearborn MI
313-336-1896
26-07-23 03:54 AM
I will also add retry logic on top of other suggestions mentioned by the other members.
Retry logic will check browser extension error or not, if it is browser extension it will kill the process and wait for 5 seconds and then launch again
I suggest to include the retry logic in process level
Harish Mogulluri
Lead developer
America/New_York TX
Harish Mogulluri
26-07-23 06:38 AM
Hi Sheela,
We've implemented the logic in the following thread which commendably decreased the browser extension issue.
Babjee Vangipurapu
Senior RPA Developer
Wonderbotz
India
India
01-08-23 02:56 PM
HI Sheela. I would recommend adding a wait or sleep stage (we use 10 sec) between killing a process and launching, again. This has dramatically decreased the browser errors we are getting when launching.
Melissa Nail
AVP, Automation Controller
BOKF, NA
America/Chicago
