Best way to Close EDGE tabs
CarlosGomez1
Hi Experts,
 I converted my Bots from IE to Edge, but I'm having problems because the process sometimes loses the map of the fields to close the EDGE tab. so I have to spy the active tab again...
that's not difficult, it's just that where I work, you have to do documentation, justify the change and submit a ticket to promote the change to production and that takes time.
Could some of you guide me on the best way to close the active tab using EDGE?
My Blueprism version is 7.1.
Carlos Gomez
10 REPLIES 10
Thank you for your help!!
Carlos Gomez
