Hi Shruti,
The spying mode will largely depend on the type of browser that you are using where you can go by a mix of Browser mode and AA mode as and when required on the basis of the element recognition. However, my suggestion would be to go via the API approach if possible as in past I have done something similar with Tableau for generating dashboard reports. You can find more details here:
API's for QlikSense------------------------------
Website:
https://devneet.github.io/Email:
[email protected]----------------------------------
