Blue Prism Discovery Tool
MiguelCarrillo
Thanks in advance.
What is the purpose of the BPDiagnostics tool that is host inside the blueprism installation folder?
Is there any advantage to use this tool instead of creating an application modeller directly  insinde object studio?
Does anybody have used this tool through their workflow?
Is there a possible way to inspect applications without the blue prism installation?
Miguel Carrillo
PSSupport
Hi Miguel - it's a test/investigation tool that dates back from early versions of BP. It's not used much these days and I think the Support team will occasionally ask clients to use it to extract information to help with diagnosing problems.
PS Support
PS Support Account for all of Professional Services
