Hi, Abishek,
did you check the server requirements. Redis should be installed automatically and is part of BPPI installation package. But the server where you install it must support WLS so check whether it is the right version. Did you download the prerequisites?
1. gcc-10-base_10.3.0-1ubuntu1_20.04_amd64.deb
2. libatomic1_10.3.0-1ubuntu1_20.04_amd64.deb
3. CanonicalGroupLimited.UbuntuonWindows_2004.2021.825.0.AppxBundle
Zdenek
Zdeněk Kabátek
Head of Professional Services
NEOOPS
http://www.neoops.com/Europe/Prague
