Base URL launch error after process intelligence successful installation 2.1v.
Hello! I successfully installed Process Intelligence, but I'm unable to open the Base URL configured during installation. The TimelinePI services are running, but when I try to access it using my local IP address and port number, the web page loads. However, after entering my username, it redirects to my Base URL and I get a "can't reach page" error. Can someone help me figure out where I can fix this?
Below is the configuration of my timelinepi.xml file:
<env name="BASE_URL" value="http://mytimelineprocess.com"/>
<env name="PROXY_PORT" value="80"/>
I'm trying to open Process Intelligence through this link: http://mytimelineprocess.com:80
Any suggestions @Neel1 @alexhim
Neel1
Hello @srikanthpabbathi  - Sorry i dont have idea on installation front.
and Alex has left SS&C so we need to wait for expert from BP to reply on this. You can also raise ticket if it is blocker for you.
also, I am sharing the document link for BPPI installation. Pls check if it help you.
https://docs.blueprism.com/en-US/bundle/process-intelligence-2-1/page/installation/installation-components.html
