Blue Prism certification - Solution designer (ASD01) guides
SindujaNehruji
Hi, I plan to take the ASD01 - Blue prism solution designer certification. in the certification details document, I saw that the guides below are needed to be read for preparation.
Blue Prism - Solution Design Overview
• Work Queues Guide
• Blue Prism User Guide - Web Services or v6 User Guide - Web Services
But I unfortunately cannot find these guides in the documents section. Can someone please give the direct link of these guides and any other guides I need for the preparation of this exam?
Sinduja
expertcr
For the Web Services is located in the Documentation section of the Portal, I look for "Web Services" this is the link https://portal.blueprism.com/system/files/documents/v6%20User%20Guide%20-%20Web%20Services.pdf
For the Work Queues, Guide will be attached to this message.
SindujaNehruji
Hi Luis,
Thank you very much for your help. 🙂 By any chance, do you have the solution overview design document?
