Blue Prism works within Citrix?
13-03-19 12:46 AM
If I have BP installed inside Citrix, does it work properly or does it have restrictions? Can bots be developed without problems? if I install BP inside Citrix?
do you know an existing article???
13-03-19 05:54 AM
Yes, the BluePrism works perfectly inside Citrix VDIs. I have BP inside VDIs itself and the bots work perfectly.
13-03-19 06:14 AM
Thank you very much for the answer. Do you know of any manual or article from BP so that I can share with my client?
