Blue Zone Mainframe Connection
17-11-17 02:10 AM
how to connect blue zone mainframe application with blue prism?
17-11-17 02:46 PM
You need a running mainframe session, then you can attach to it. See Customer Service/Documents for how to set up modeller
04-12-17 06:59 PM
I'm also trying to connect to a BLue Zone 7.1 Mainframe Session using the instructions I found in the documents for how to set up Rocket BlueZone Mainframe Emulator.
I always get the same errormessage:
'Failed to launch application - Launch failed: Error from ConnectToHostOrSession: An incorrect host presentation space ID was specified. The specified session either does not exist or is a logical printer session. This return code could also mean that the API Setting for DDE/EHLLAPI is not set on. Return code: (1)'
04-09-20 10:13 AM
Hi there,
Did any body got the solution for this, i am in the same place, it just fails to attach the main frame window
Adarsha Bari Sharnappa
