Try checking if the extension is installed and active on Edge.
Can you try installing the extension using the Blue Prism installer from the Windows Control Panel and pick CHANGE?
Pick CHANGE FEATURE
if Edge is Browser extension is selected, try unchecking the box and install, restart, and again enabled again.
Also, we have some know issues with version 6.8 and Edge; please look at the following
link.
If you keep having issues, please create a ticket or email
support@blueprism.com to take a detailed look at your case.
Luis Lopez
Blue Prism Ltd
