BluePrism 6.10 Chrome extension issue
vinithchandra3
Hi Team,
At present, I am using blueprism V6.10.1. When I try to launch an application through any one of the browsers(Edge and Chrome). Sometimes I am facing attach issue because of a browser extension and also I tried it multiple times. Even though I selected the browser Extension Connectivity option in the settings tab.
Failed to launch application - The browser extension was not detected, please check that it has been installed and enabled. For more information, see the browser extension user guide.
https://bpdocs.blueprism.com/bp-6-10/en-us/Guides/chrome-firefox/chrome-firefox.htm
Vinith
Developer.
vinith chandra
11 REPLIES 11
Hi Philippe,
I never used Edge on a fixed port, but it seems that BP searches in very window.
But if you are using different Edge windows at the same time there is the concept of "tracking ID".
If you use a launch action there is an optional output "Tracking ID" store this ID and use it in every action against the specific target.
Tobias Arnold
ITERGO GmbH
Europe/Duesseldorf
Thanks a lot Tobias. I was sure it will be a workaround.
By the way thanks also for your VBO ToArnoldJsonXML BO, was a great use to me.
philippe boutry
Blueprism Solution designer
Aubay
Europe/Paris
