Bot not reading the comment box correctly with multiple lines
SivapriyaS
The Bot is reading a comment box which has multiple lines in it. When it is read, the end result does not have the space between each lines.
For eg:
Actual Comment -
Send Financial Statement to (Mark) to forward
to donor
Bot Read Comment -
Send Financial Statement to (Mark) to forwardto donor
Can someone help me here to read the comment box correctly.
Thanks In Advance
Sivapriya S
Hello, check this article, the problem is very similar to yours: https://community.blueprism.com/discussion/split-text-into-multiple-lines
Also, could you do a test? Check what the html output looks like if it has a line break delimiter, you can capture the html value and carry out the necessary processing.
Leonardo Soares
RPA Developer Tech Leader
Bridge Consulting
América/Brazil
