[Bug] Drag and drop objects between groups with same name
mikolaj_mackowi
Hi, I noticed a weird bug in using Studio's tree browser - that you cannot move objects from one group to another if those groups have this same name. Example: 1. Create two groups: Application1, Application2 2. In both groups create a group called: "Common" 3. In Application1/Common create a bussiness object "Test" 4. Drag object "Test" from Application1/Common to "Application2/Common" Expected result: Object will be moved Actual result: Object remains in Application1/Common This happens on 5.0.30 Also, same thing happens when you create a group called "Objects" and you try to move an object that is directly under main "Objects" branch.
It might be worth raising that in the ideas and enhancements area of the Forum, the product team monitor that thread and will pick up your feedback.
mikolaj_mackowi
Thanks, moved.
