[Bug] Drag and drop objects between groups with same name
28-08-17 02:47 PM
I noticed a weird bug in using Studio's tree browser - that you cannot move objects from one group to another if those groups have this same name.
Example:
1. Create two groups: Application1, Application2
2. In both groups create a group called: "Common"
3. In Application1/Common create a bussiness object "Test"
4. Drag object "Test" from Application1/Common to "Application2/Common"
Expected result:
Object will be moved
Actual result:
Object remains in Application1/Common
This happens on 5.0.30
Also, same thing happens when you create a group called "Objects" and you try to move an object that is directly under main "Objects" branch.
29-08-17 02:56 PM
It might be worth raising that in the ideas and enhancements area of the Forum, the product team monitor that thread and will pick up your feedback.
05-09-17 02:55 PM
Thanks, moved.
