11-02-25 09:25 AM
I've been trying to log in to the Blue Prism Client, but this window appears, and nothing happens.
Just to clarify:
Thank you for your attention.
10-03-25 12:05 PM
If possible can you please check the Windows Event Viewer logs for the timestamp of the BP login
Best Regards,
Sayeed Bin Abdullah
11-02-25 11:50 PM
HI @knowmad.jhermoso
When you try to configure the connection, Did you get chance to test the connection?
Below screenshot is just for reference i took the screenshot from the learning edition . you need to select appropriatley based on how you want to connect client to the server,
12-02-25 01:42 PM
Hi!
Yes, I did it. It appears a window with the message "Connection valid".
07-03-25 01:51 PM
Hello, I still need your help with this, the problem remains.
08-03-25 10:41 PM
Are you facing this issue with one client machine or is it with multiple machines?
Does BP throw any error/popup after trying to connect to server after certain time or it remains on this screen?
Best Regards,
Sayeed Bin Abdullah
10-03-25 08:24 AM
Hello!
I'm facing this issue with two machines. They're connected to a load balacing domain.
BP shows this error and, sometimes, it throws a popup telling that there's an error at referencing the server. Most of the time, it justs remains trying to connecting the server.
Best regards.
10-03-25 08:37 AM - edited 10-03-25 08:38 AM
Have you compared the BP version of these two client machines and the machines which are working fine?
What is the version of BP on server and client machines?
Best Regards,
Sayeed Bin Abdullah
10-03-25 11:49 AM
Client machines and server machines have 7.3.1 version of BP.
10-03-25 12:05 PM
Best Regards,
Sayeed Bin Abdullah
a month ago
Thank you for acknowledging my response as the best answer.
Could you please share what was causing the issue?
This information could be beneficial for anyone encountering a similar problem in the future.
Best Regards,
Sayeed Bin Abdullah
