28-05-25 03:18 PM
Hi all
Currently using Capture v4.0 - has anyone experienced any issues with CPU performance whilst using the Capture tool? Reports from SMEs have indicated CPU spiked where doing their "day to day" activities was almost impossible as it slowed down laptop performance.
Just wondering if anyone has come across anything similar?
Thanks in advance
Kevin
28-05-25 03:30 PM - edited 28-05-25 03:32 PM
Hello @Kevymc - Can you check on two thing.
1. Do SME's system meet the system requirement required for capture.
2. is it happening for every recording?
also, i am sharing two link where you can check system requirement plus limitation
https://docs.blueprism.com/en-US/bundle/capture-4-0/page/install/step-limitations.htm
https://docs.blueprism.com/en-US/bundle/capture-4-0/page/install/requirements.htm
06-06-25 10:47 AM
Thanks very much - very helpful!
