Chrome attach issue in BP 7.1.1
AmulrajDhanabalBP
We're running version 7.1.1. and Blue Prism 7.1 Browser Extension was installed.  The application launches, but if detached or using another Object. Then, trying attach the running chrome. But attach is taking more time and getting failed attach the chrome.
I've given process name as "chrome"
chrome version 117
Any help/solution would be appreciated.
Hello, Amulraj Dhanabal
The application to open should read "chrome.exe," as you are telling it to open the specific chrome file in the setup of the application modeller. But you also mentioned that you are trying to attach to an already open page and not open the process from scratch, so it should be the name of the available page, such as google.com if you are opening to google.com.
I suggest reading through this guide, Troubleshooting Browsers : (blueprism.com), to see our best practices and most common issues with browser automation.
This could also be relevant since you are on the version of Chrome that is affected by this issue, and you may need to add extra parameters to your application modeler.
[NOTIFICATION - UPDATED 16-Oct-23] Latest versions of Google Chrome and Microsoft Edge browsers have resolved issues with User Interface Automation (UIA) and Active Accessibility spying in Blue Prism ...
