Citrix Automation BP V7
27-05-21 10:17 AM
To do Citrix automation it is mention in the online document that we need to install BP V7 on both external/primary machine and also inside Citrix VM as well. i.e.In the VM itself and in the machine from where Citrix VM is started.
Is this the right understanding that if we want to do Citrix automation one has to install and set up blue prism enterprise V7 in both of the machines?
Thanks & Regards,
Tejaskumar Darji
Thanks & Regards,
Tejaskumar Darji
7 REPLIES 7
27-05-21 03:26 PM
That is correct. According to the online help here it sets it out with these items:-
John Cowell
Senior Software Support Analyst
The following steps must be completed to automate applications via a Citrix VDE:
- Install Blue Prism on the Citrix VDE.
- Install Blue Prism on the interactive clients used to build processes and on the runtime resources used to run the processes.
- Automate applications via a Citrix VDE.
John Cowell
John Cowell
27-05-21 03:50 PM
Then why is it call separate Citrix automation? Isn't it like making the Citrix VDI as a run-time resource?
I mean technically we are installing BP on both machines right.
Thanks & Regards,
Tejaskumar Darji
28-05-21 12:59 PM
The installation of BP on the Citrix VDE provides the means to install and configure the necessary software to allow a runtime resource to communicate with the Citrix VDE. The runtime resource communicates via the ICA channel to the AppMan.Service.exe on the Citrix machine which is the part that interacts with a target application. So the runtime resource is executing Blue Prism processes whereas the application instructions from objects in that process are communicated to the Citrix VDE and the target application with this method.
John Cowell
John Cowell
John Cowell
01-06-21 05:55 AM
Hello John,
I have a question regarding the BP installation part in Citrix VDE.
Q: While Installing the BP in Citrix VDE is it ok if we select the 'Citrix Automation' under the 'Additional' section? Will this allow us to automate the Applications within this Citrix VDE from another resource PC?
Vivek Kaurav
Vivek Kaurav
02-06-21 01:47 PM
@John Cowell - Is this the right understanding. Can you help us understand setting up Citrix automation?
Q1: While Installing the BP in Citrix VDE is it ok if we select the 'Citrix Automation' under the 'Additional' section? Will this allow us to automate the Applications within this Citrix VDE from another resource PC?
Q2: Instead of Citrix VM can we use windows RDP to automate? Or is it like exclusive for Citrix only?
Thanks & Regards,
Tejaskumar Darji
Thanks & Regards,
Tejaskumar Darji
03-06-21 09:22 AM
Hi Vivek, according to the install guide you do not need to select this on the Citrix VDE for the BP installation, only on the required interactive clients to build processes and the runtime resources that will be used to run them.
John Cowell
John Cowell
John Cowell
03-06-21 09:28 AM
Hi Tejaskumar, according to the guide you only need to select the 'Citrix Automation' option when installing on the IC used locally to develop processes for Citrix VDE automations and the runtime resources used to run these processes. The Citrix VDE machine itself does not require this option to be selected.
This Citrix integration is purely for Citrix VDE and does not support Windows RDP.
Hope that helps.
John Cowell
Hope that helps.
John Cowell
John Cowell
