04-03-20 12:06 PM
I have action which remove duplicated rows in whole collection.
Collection_Out = Collection_In.DefaultView.ToTable(True)
I want to write new action which remove duplicates value only in specific column.
Does anyone have solution for this?
Thank you in advance
Mateusz Wojcik
RPA Programist
Rockwell Automation
Europe/Warsaw
05-03-20 08:05 AM
Dim c As Integer c=Cint(cNumber) Collection_Out = Collection_In.AsEnumerable().GroupBy(Function(row) row(c)).[Select](Function(group) group.First()).CopyToDataTable()
Add cNumber as Number Input referring to column number starting from index 0
ALso add following to Imports
Gopal Bhaire
Analyst
Accenture
04-03-20 01:18 PM
Hi, Mateusz.
You can try to use the asset from Digital Exchange called Millicom – Collection Utility.
You can find the action the extract unique values (or remove duplicates) from a collection and other nice actions to work with collections.
------Original Message------
Mateusz Wojcik
RPA Programist
Rockwell Automation
Europe/Warsaw
04-03-20 01:26 PM
or you can choose to write a code stage as well.
Ishan Mahajan
India
04-03-20 01:42 PM
Ishan Mahajan thank you for this solution.
I am wondering if there is a way to extand code Collection_Out = Collection_In.DefaultView.ToTable(True). This will contains less stages. than looping through whole collection.
Mateusz Wojcik
RPA Programist
Rockwell Automation
Europe/Warsaw
04-03-20 01:43 PM
I think you can use DISTINCT to get the result you need.
Try it and lets see if works.
Raúl Hernández I do not see those actions in Millicom – Collection Utility. Please see attachment
Mateusz Wojcik
RPA Programist
Rockwell Automation
Europe/Warsaw
04-03-20 02:04 PM
I lost others columns.
Mateusz Wojcik
RPA Programist
Rockwell Automation
Europe/Warsaw
04-03-20 03:14 PM
I understand.
In that particular case, you can use a simple loop logic to get unique values from the collection.
Simple loop logic should use
- A mirror collection, to compare all elements.
- A new collection to store unique values (entire row).
- A loop inside other loop, to compare all elements.
- a Flag to identify if the element already exist in your new Collection.
This logic is high time consuming depending of the numbers of rows in your collection, but it will work.
DISTINCT action return a collection with unique values and column counter
Mateusz Wojcik
RPA Programist
Rockwell Automation
Europe/Warsaw
05-03-20 06:42 AM
I am looking for less time consuming way, like extanding code Collection_Out = Collection_In.DefaultView.ToTable(True) by additional argument or additional line.
Mateusz Wojcik
RPA Programist
Rockwell Automation
Europe/Warsaw
05-03-20 08:05 AM
Gopal Bhaire
Analyst
Accenture
05-03-20 01:02 PM
This is want I was looking for.
It works.
Thank you very much.
Mateusz Wojcik
RPA Programist
Rockwell Automation
Europe/Warsaw
