Comma/Semicolon Issue in Expressions
23-01-17 01:37 PM
Hi all,
I am facing one issue related with comma and semicolon. I am receiving the following error message:
Internal: Failed to evaluate expression in row 2 of Write stage 'Write Data' on page 'page' - Misplaced "
When I try to Evaluate Expression is because it is trying to find the character: , as a separator instead of ;
As an example, I have: Replace("text"; "e"; "o") and BluePrism is trying to find: Replace("text" , "e" , "o").
The funny part is if I click on Evaluate Expresion, then it is working and BluePrism is recognizing both of expressions...but is not saving the changes and when I retry to launch the process from control room the issue is back.
Before it was working properly so I can't understand what happened, I also tried to change computer settings changing List separator symbol.
Any thoughts about this?
Please, notice that changing all semicolon for commas is not a real solution, since I have several objects and all of them were working properly, so I would rather try to find the problem.
Thank you very much in advance,
Ismael.
23-01-17 09:46 PM
That error suggests that there is an expression where the "" quote mark is not being used properly. To return the value A""B""C the expression needs to be ""A""""B""""C
