Connection Lost Control Room
Hans_DanyCampos
Hello everbody,
Please I need a support to fix the following issue
I don´t have a digital worker that I could connect (look at the image attached)
I tried to fix it by manually enabling the resource in settings but it did not work.
I looking forward to comments
Dany
Dany Campos Armas
GopalBhaire
Level 10
Check if Start Personal Runtime is enabled in System Setting. also check if Resource Pc icon is running in deskband restart it if required. If that doesn't work run the resource pc command
[Blue Prism Install Location]\automate.exe /resourcepc /public
null
Gopal Bhaire
Analyst
Accenture
