Control Room: Connection Lost
Prasad10
I am using Learning Edition.
It is logging to the account fine. Got License setup fine.
When I go to Control Room, I see the
status: Missiing
Session Info: Connection Lost
Please see attached screenshot.
It is  installed on local PC and BPServer is not authorized in Learning Edition.
Please advise how to fix this issue.
Prasad
Prasad10
Prasad10
Found the Solution.
GoTo System, Scroll to the System and click Settings.
When the settings Screen opens,
Check the box under Local Devices which says Start a personal Runtime Resource on this machine when users sign in to Blue Prism.
It connects to your local Workforce.
See Screenshot.
Prasad
Prasad10
Hi Prasad.
Thanks for letting us know you successfully resolved the issue as well as provided the solution.
Much appreciated.
jack
Jack Look
Sr Product Consultant
