Could not identify process owning the current foreground window - Alternate solutions?
IshaSingh
Hi Everyone, I am facing an issue while activating an excel window via my VM. I have used AA for spying the excel since it has customised tabs that need to be clicked. I am using the toolbar to activate the window. When I perform a check exists on it, it finds it but on using Activate it throws the error 'ERROR: Internal : Failed to perform step 1 in Navigate Stage 'Activate Excel' on page 'Supplier Search' - Could not identify process owning the current foreground window'. I have gone through the Knowledge Base article on this error but the solutions aren't suiting my process. The solution list is: Use the Activate Application function on a Win32 or AA element with the whole application selected: The error itself comes on Activating an application. Setting the Focus on an element within a window, if that action is applicable to the element: The same error comes when I try to focus same element. Immediately after a Launch action has been used, set a conditional Wait for an element of the application before attempting the next action: This is already in place and there are multiple element checks and interactions which come successful. Any help or ideas would help. Thanks, Isha.
10 REPLIES 10
gouthamedara
Andrzej.Kaczor, That is good for one instance. What if this is happening regularly? I believe we are following all the security policies as mentioned in the BP document. I am confused why this is still happening.
