Decipher cannot extract a specific column data when it is split into 2 pages
17-08-22 05:41 PM
Hi all,
I have an use case where I need to extract the table data which does not have borders. The data is scattered and also dynamic. This table data might have specific column data might be present or may not present. but there is a pattern on the rows. One of the column's data is extending into another page and now only one column data is extended but the other fields of the row are not extended.
I have tried to Merge the pages during the class verification but they are coming up as separate pages when it comes to data verification. Can someone please help me with this issue. Thanks in advance.
Srikanth P
Srikanth P
18-08-22 08:15 AM
Hi Srikanth,
I believe I've seen similar documents, where the description for a line item is quite long and spans onto a second page. Unfortunately at this time Decipher doesn't support values that run over to a second page, but it is in our feature requests and we'll be looking to include it in a future version (hopefully 2.3).
Ben Lyons
UK based
Ben Lyons
UK based
Ben Lyons
SS&C Blue Prism
UK based
SS&C Blue Prism
UK based
18-08-22 03:04 PM
Thanks @Ben.Lyons1, for the response. I will try a different route of pulling the whole data and manipulate the data in Blue Prism.
Srikanth Parasa
Srikanth Parasa
