Difference in Datetime in Blueprism
GuptaKancharla1
Hi, SQL server has been installed in US machines and it is considering those machines current date. When we are trying to fetch that date from our database through Blueprism we are getting the different date as UK time. Can you guide how to fetch the datetime as per local system. Do we need any separate configuration on Blueprism side. Please suggest. thanks in Advance
This document might be of help http://portal.blueprism.com/system/files/2017-11/v6%20Data%20Sheet%20-%20Date%20and%20Time%20Handling.pdf
