Double Approval
03-11-21 11:54 AM
Hi Everyone,
I need for a project to have 2 approvers approving the data within a template . Anyone knows of a way to do this?
regards
Andrei Cozma
Data
Zurich
Europe/Madrid
regards
Andrei Cozma
Data
Zurich
Europe/Madrid
03-11-21 12:18 PM
Hi Andrei,
A feature that allows multiple users work on the same form is on the product roadmap. As far as I know, the current iteration of the product does not natively allow for more than 1 approver.
A solution I have used is
- After a submitter has submitted a form, the Digital Worker uses Raise Submission to create a new instance of form (containing the information to be approved) in the inbox of the first approver.
- The first approver sees the form in his inbox, selects a radio button to indicate approval or rejection, and submits the form.
- The Digital Worker uses Raise Submission to create another instance of the form (containing the original information plus the information that the first approver has approved) in the inbox of the second approver.
- The second approver does as the first approver did.
Thanks.
Alfred Lau
PS EMEA
Alfred Lau
Product Consultant
Thanks.
Alfred Lau
PS EMEA
Alfred Lau
Product Consultant
Alfred Lau
Professional Services EMEA
SSNC Blue Prism
SSNC Blue Prism
