Edge Extension issue
EricLi
We upgrade current Blue Prism to 6.10.4 version. When we check the extension enabled or not by using address: edge://extensions, the admin account which upgrade BP show the extension has been installed and enabled. While we check with robot account, it indicates extension has not been installed. Try to installed from MS Web Store, an error pop up. How can I address this issue? Is it  account authority issue?
This is Admin Account
This is robot account
Try to Get from MS Web Store
Eric Li
Operation Analysis
AIG
Asia/Hong_Kong
JacobClary
Hey Eric,
Was this previously an issue with the robot account? I am thinking what you are thinking, that it could be an account issue. I am wondering if it is a permissions issue and if your domain policy does not allow extensions to be installed unless the proper permissions on the user are present. I think this would be something to look into if possible if this has not worked before and this is the first time you are setting this up.
Jacob Clary
Customer Support Engineer
Jacob Clary Senior Product Support Engineer Blue Prism
Hi, Jacob
This is first time setting extension up. We are trying to extend account permissions to see if issue can be fixed. But quite strict IT policy may make it difficult. So I wonder if robot can work on edge/chrome without these extension set up.
Eric Li
AIG
Automation Delivery Team | China Service Center
9F, The Centerpoint (Shuion), 374-2 Beijing Road, Guangzhou, China 510030
Tel: (+86 20) 2882 5022
[email protected] | www.aig.com
IMPORTANT NOTICE:
The information in this email (and any attachments) is confidential. If you are not the intended recipient, you must not use or disseminate the information. If you have received this email in error, please immediately notify me by "Reply" command and permanently delete the original and any copies or printouts thereof. Although this email and any attachments are believed to be free of any virus or other defect that might affect any computer system into which it is received and opened, it is the responsibility of the recipient to ensure that it is virus free and no responsibility is accepted by AIG for any loss or damage arising in any way from its use.
