Edge extension Browser mode not working on a few websites
MaheshNandanan
We are using BP 6.8.1 and doing browser migration. But for a few websites edge browser mode spying not working.
Mahesh Nandanan
Software Architect
UST Global
KaranSareen
Hello Mahesh
Hope you are doing great.
Are you migrating to Edge from IE?
Usually when we migrate from one browser to another then few of the spied elements might need to be re-spied as there is a change in the environment which can affect the value of the attributes. Can you try re-spying the elements and let me know if they can be spied and highlighted successfully?
Karan Sareen
Solution Support Engineer
Blueprism
Australia/Sydney
Rambo27
Level 8
Hi Mahesh,
Even in migrating or making launch any application in Edge and starting with automation .
You need to follow all extension and setting before it in order to make the application modular spy the elements.
Please refer - Data Sheet For Browser Integration
Edge is compatible from 6.8 version so it should work fine from there onwards.
Please call out if any help needed.
Shikhar Mishra RPA Lead
Shikhar Mishra
RPA Lead
Hello Mahesh - My suggestion would be first read all the known issue w.r.t browser mode  functionality in that BP version. Link is below.
Apart from this - do post some error or snapshot of issue your are facing.
http://portal.blueprism.com/customer-support/support-center#/path/Upgrade-Expansion/Upgrade/1490225772/What-are-the-known-issues-in-Blue-Prism-Version-6-8.htm
Neeraj Kumar
Software Engineer
